145
Changing MdiParent will remove context menu in grid
I have a problem with changing MdiParent.
My app is like this.
I have two forms with UltraTabbedMdiManager in each form. I added a context menu on the Tab it self to be sent between the two forms.
I was using this code to send it between the forms:
a.MdiParent = Nothing
a.MdiParent = m_SencondaryMDIContainer
I needed to add MdiParent = Nothing to even get the form to be loaded correctly in the new MdiContainer.
But when I did that I lost the context menu of the Grid that I have in the MdiChild.
If I skip the MdiParent = Nothing then the context menu is still there but then it will not be loaded correctly.
Can this be done in some other way?
