Is there a way to extend the list of shortcut key mnemonics? Currently, I can select a shortcut for each tool from a constant list of shortcut key combinations using the UltraToolbarsManager. However, I want to extend this so that my shortcut keys can group tools that are in a similar family.
An example of what I am trying to accomplish can be seen in Microsoft Visual Studio 2005. If you click on the View menu, the popup menu shows a group of commands for window operations (e.g. Error List, Output, Properties Window, Task List, Toolbar...). Each of these tools has a mnemonic that begins with Ctrl+W, and is post-fixed with another key that pertains to a given window type (Error List = Ctrl+W, E, Output = Ctrl+W, C, etc).
Is there any way to extend the list of shortcut key options, or am I limited to the list of key constants given in the shortcut enumeration?
Thanks in advance for any help!
********* New comments as of 3/26/08 *************
I have half of the answer to my question. I think that I could write a new command that is associated to the Ctrl+W key combination. When this command is invoked, I can then listen for the next key input and then launch the appropriate command that matches that key. This would work, but I would need to override the shortcut key text in the popupmenu. Is there anyway to do this? What I mean is, can I specify the right-aligned text (e.g. Ctrl+W, C)?
The feature requested in this thread has not yet been implemented. You should submit another feature request if you want this feature as well because the number of requests for a particular feature does get considered when determining what to implement each release.
Any news about that issue? I need to show shortcut keys combination right-aligned in the context menu but see no way how to do it.
Thanks Mike. I just submitted a feature request for the shortcut "group" functionality.
This is not possible publicly. You can try using creation filters to change the text of the elements created for the shortcuts. However, I don't recommend this approach because you will need to also re-implement the measuring of each menu item and set a custom size of the menu drop down when it is first shown. I would recommend either submitting a feature request to override the shortcut text or a feature request to allow these extended style shortcuts: http://devcenter.infragistics.com/Protected/RequestFeature.aspx.
