i've a UltraTree with Viewstyle Grid. DataSource is an DataView. After Change Sorting the most data is'nt show again. after Clicking a scrollbar data is back.
you can test with your §freeform" sample. Click to sort by "First Name" .. it seems to be a bug
so i've testet die SR. it works better but it does not really always solve the problem. after changing sort direction of serveral columns the scrollbar ist always on right top side. after clicking sctroll down more treeitems are shown.
Hello Thomas,
Please let us know if you still experiencing your issue with the latest service release available for your version which is NetAdvantage 2010 vol3 .2067
Hi Thomas,
I just tested this out using our "FreeForm ViewStyle CS" sample with our latest internal build of the assemblies and it's working just fine for me. So I'm pretty sure this issue is fixed.
Now... there was a service release that was posted just a couple of days ago on March 15th (Tuesday).
I am not sure if the fix made it into that release, but if you want to try it, here's How to get the latest service release - Infragistics Community.
If it's still not working, then the fix didn't make it and it will be in the next one. You can see the service release schedule here: Infragistics Service Releases
we are using 10.3
What version are you using?
I beleive what you are reporting here is a known bug that will be fixed in the next service release.
