4695
title and add rows
Dear all,
(1) I have set this.ultragrid1.Text="xxxx", but the text does not show??
(2) If I have created the static DataSet and assign to the ultragrid, How can I make it be able to add rows or data?? As This DataSet is blank at first, it only store the added data and ADD to the DB when OK Button clicked.
  • 469350
    The grid caption is visible by default. So if the text is not showing up, either something in your code is clearing out the Text property after you set it, or something in your code is setting the grid.DisplayLayout.CaptionVisible property to False.
    Set the AllowAddNew property on the grid.DisplayLayout.Override.
