Is it possible to use custom business objects in multiband?For single band I use and custom bussines object and a bindingmanager.At the moment when I need and grid with multiband I use and dataset or ultradatasource and copy the data to the source. Is there a way to do this without copying the data?
I just wanted to know if you were able to solve your issue based on my suggestions or you still need help. Just let me know.
Thank you.
Yes it is possible, please look at the following forum thread where Mike explain how you could achieve this.
http://forums.infragistics.com/forums/p/38963/222476.aspx#222476
Let me know if you have any further questions.
