I'm wondering if there is a way to 'wordwrap' something in a cell. Here is what I'm trying to do. I click a button and it opens up a button with an ultragrid on it. It shows the user past SQL they've done. However, if the SQL is like this :
Select *
From History
Where Dog = Collie
The only thing the table shows is the first line (Unless you run over it with the mouse). Is there a way to sort of word wrap it into the following : Select * From History Where Dog = Collie
I've tried using the following code which I thought would work but it doesn't.
[Code happens that calls upon the loading of the table]
Public Function HistoryTableSelectSubset(ByVal maxRows As Integer, ByVal blnUseTree As Boolean) As DataTable
Dim strSQL As String
Dim dt As New DataTable
InitializeConnection(conn)
conn.MaxRecords = maxRows
strSQL = "SELECT TOP (" & maxRows & ") SQL, QUERYDATE, Replace(Replace(Replace(CAST(sql AS NCHAR(1000)), unicode(10), ''), unicode(13), ''), ' ', ' ') AS ONESQL FROM HISTORY WHERE NODETYPE = '" & ApplicationConstants.QUERY_DATA & "' ORDER BY QUERYDATE DESC"
dt = conn.ExecuteQueryDT(strSQL)
Return dt
End Function
This calls back the Query Date (works!), the original SQL (Works), but the third column ONESQL doesn't show all the SQL on one line. Just does the normal thing.
Any help you can offer would be appreciated. Any reading materials or if you suggest an easier method, that would also be appreciated!
You can set the cell to multiline:
column.CellMultiLine = Infragistics.Win.DefaultableBoolean.True
