1055
Problem formating cell value
Hallo,
 Ich have a ultra grid with a column that contains a double value. I want to display the engineering unit within the cell. The problem is, that rows can have different engineering units. The Format property is only at the column and not at the cell.
But I don't want to write the double value and the engineering unit as string in the cell, because I want to filter the double value.
Any body an idea?
  • 469350
    Verified Answer
    There are a lot of ways you could acheive what you want here. But it depends on a number of factors.
        You could implement this using a CreationFilter - which would allow you to change the text being drawn by the grid without affecting the value.
        You could use a DrawFilter to draw the text yourself - again this would not affect the value.
        You could use a DataFilter to translate the value to and from the displayed text.
