1339
DateTime masked edit zero fills on character delete
I've been struggling to identify the source of some weird behavior when using a custom input mask on a DateTime backed column.  I'm using a fairly typical date format as follows:
 UltraGridColumn someDate = columns["SomeDate"];
 someDate.MaskInput = "yyyy/mm/dd hh:mm:ss";
Now when editing this field, if you place the cursor between the 3rd and 4th digit of the year and hit the "delete" key, it properly deletes the last digit of the year but it sticks a zero in it's place. Since the zero is there you can't enter a new digit.
Pressing the delete key with the cursor in any other position within the entire datetime string does not have this issue (deletes properly and shows the blank '_' character of the mask and allows another digit to be entered).
Thanks! Any insight would be greatly appreciated!
(This is with version 2009.2).
Parents Reply Children
No Data
