Is it possible to hide the chart area?
Ok thx for your answer.
No. The control exposes a ChartAreaWidth property, which you can set to reduce the width of the chart; I forget what the minimum allowable value is (from what I remember zero is either not supported or means default value), but you could use that property to reduce the size of that element.
