380
Couple of Dock Questions
I have an application that requires a section be a dock for three tabs.  To create this I made a user control and then added that control with the three control panes to my main form.  This works like I want.  However there are a couple of things that I would like to change.
1.  The user can un-dock the entire thing from the form (UltraDockManager and all three tabs).  Is there a way to prevent this so that only the tabs can be moved?
2.  The Caption and Tab are redundant when the tab is docked.  How would I hide the caption when the tab is docked, so it only appears when it is floating.
  • 53790
    Have you been able to resolve your issue ? Please keep me in touch.
    Regards
  • 53790
    It is possible and I suggest you to use some of  the properties below:
    [code]
    DockableGroupPane
    dgpLeft = new DockableGroupPane();
    DockAreaPane dapLeft = new DockAreaPane(DockedLocation.DockedLeft);
    dgpLeft.DockAreaPane.Settings.AllowFloating = Infragistics.Win.
    DefaultableBoolean.False;
    OR
    dapLeft.Settings.AllowFloating = Infragistics.Win.
    OR
    dapLeft.Panes[0].Settings.AllowFloating = Infragistics.Win.
    [\code]
    Please if you have any questions do not hesitate to ask me
    Regards
  • 380
    I may have posted one of those question too soon.  I just added the following that I think will take care of Q2. I used the DockChange event to manage the pane's Caption.  I suspect that I might be able to disable the un-docking of the main control as well.
