460
EnterEditMode fires Enter event and throws non-fatal exception
I have an ultraGrid,
my goal is when the user tabs into the grid the new template row should get activated and the first cell in Edit mode, ready to type.
i set the AllowAddNew to FixedAddRowOnBottom
then i wrote the 2 simple lines in the grids Enter event:
Private Sub myGrid_Enter(ByVal sender As Object, ByVal e As System.EventArgs) Handles myGrid.Enter
Me.myGrid.Rows.TemplateAddRow.Cells("Column1").Activate()
Me.myGrid.PerformAction(Infragistics.Win.UltraWinGrid.UltraGridAction.EnterEditMode)
End Sub
What's happening is that when it execute the PerformAction method, for some reason it causes to fire again the Enter event, and attempts to run again the Cell-Activate method, and here's where it throws an IndexOutOfRangeException, description "Index 0 is either negative or above rows count."
if i resume debugging, (I hit F5), it moves on and the error reaccures 7 times, and then after resuming 7 times, it moves on and behaves normal and as expected as if nothing happend.
The only thing I can reason why the number 7, is that is co-incidently that is the count of columns in the grid.
So what I gather is that the compiler doesn't realy consider it as a FATAL error, so it lets you move on.
Another important point this symptom only accurs when there's NO rows yet in the grid.
I can release it as is and the end-user would'nt notice anything, but its definitlely not clean.
  • 18495
    Hello Mendel,
    I created a sample project using NetAdvantage 2010 Volume 3, and everything worked without any issues.  Please let me know which version of NetAdvantage you are using.
