Just seen in your code in ColumnsCollection (v. 2010.3)
public UltraGridColumn Insert(int index, string key) { base.ValidateKeyDoesNotExist(key); UltraGridColumn column = null; if (key == null) { column = new UltraGridColumn(this.band); } else { column = new UltraGridColumn(this.band, key); } column.SubObjectPropChanged += base.SubObjectPropChangeHandler; this.InternalInsert(index, column); return column; } internal void InternalInsert(int index, UltraGridColumn column) { base.InternalInsert(index, column); this.BumpColumnsVersion(); column.SubObjectPropChanged += base.SubObjectPropChangeHandler; base.NotifyPropChange(PropertyIds.Add); this.AddRemoveColumnFromCalcManager(column, true); }
In Insert you have column.SubObjectPropChanged += base.SubObjectPropChangeHandler;then at the next row you call InternalInsert which inside does same registration second time.
Regards,Maxim Golubitsky
Maxim,
I have submitted this as a development issue with a Development ID of 70815. You will receive an e-mail with more information shortly.
Michael S.
Hi Maxim,
That looks like a bug, all right. I have forwarded this thread over to Infragistics Developer Support so they can write it up for developer review.
