I am using ultra 3D pie chart in my project. In pie chart dataset, one data is negative(-1000) and another is positive(50). When i chart displayed then 95 % of slice(larger slice) display for (-1000) and only 5 % display for value(50). Due to this wrong representation of data happing and meaning get chnaged. Logcally -1000 is less than 50 so it should be display -1000 in smaller slice and 50 in larger slice. Please help me how to handled this.
I think that you expect something impossible, because pie chart show percent of units. Let`s look on the example below:
Example: If you have 2 units and both units have negative values (for example : -100 and -50). The pie chart will show you the percent proportion of negative values. The value = -100 get bigger percent proportion than value =-50. I think it is correct. What is your oppinion ?
So I think that when you speaking about the percents in your example (Value = -1000 and Value = 50) you can concider that your negative amount get 95% of your gross amount (100 %).
Thanks and Regards
Georgi
