I'm developing on a Windows 7 computer with dutch settings. I'm working on a program where i need to summerize 2 fields and display the result in a seperate field. When i do this with standard properties it display the wrong result (see screenshot 1).
Changing the MaskDisplayMode property to RAW display the right result but without the format i would like to see (screenshot 2). I also tried using the FormatProvider property but this didn't change anything.
Another issue that i came across is when i change the NumericType property of the 3 controls to Decimal and the MaskDiaplyMode to default. In this situation the summery isn't calculated at all. (screenshot 3).
Any suggestions?
Kind regards,
Jacob Iedema
I installed the latest service release and the problem was solved. Sorry for the inconvenience.
Thx!
Jacob
Hi Mike,
I bought NetAdvantage for .NET 2010 vol 3 in january this year so i assumed i was working with the latest version but apparently this is not the case. I will install the latest service release and let you know the results.
Thx.
Hi Jacob,
These sound like bugs to me, but I seem to recall some issues like this being fixed a long time ago.
What version of the controls are you using? Do you have the latest service release?
