260
Unable to enter values in cell
We're having an issue which wasn't present in an older version we're using v 10.2.20102.1004. When I try to enter values in one of the cells that normally would except values it no longer does. There are no other events making changes to the grid or any of the cells. After reading several post on this issue here's what I came up with:
    Private Sub grdDetail_KeyDown(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles grdDetail.KeyDown
        Me.grdDetail.ActiveRow.Cells("tmpAmount").IgnoreRowColActivation = True
        Me.grdDetail.ActiveRow.Cells("tmpAmount").Activate()
        Me.grdDetail.DisplayLayout.Bands(0).Columns("tmpAmount").CellActivation = Activation.AllowEdit
    End Sub
Now this worked fine until the grid was populated with another dataset, the only way the cell then became editable was if I click on another cell and then back to the cell I wanted to edit. I can provide what ever details needed. Any ideas?
Warmest Regards,
N.
