I am creating RichTextBox control with customize text color, font size, etc.When I tried to make this RichTextBox to be dockable using UltraDockManager, my font style (color, size, etc) get lost everytime I dock/float.
I have attached my example code for reference.
Please someone give me solution for this,
Thanks before.
Edo Gasali said: @tbetts1982 After some consideration, finally I am now using UltraFormattedTextEditor as you suggest as workaround mate. Thanks for your idea.
You're welcome. The amount of code necessary to make the formatted editor a decent editor for users like that dialog would cause any programmer a headache. It's much easier to use the dialog than to reinvent the wheel. If they really intended users to click a button to open the dialog for editing an already editable textbox, why not cut out the middle man and work out a solution to combine the functionality of the dialog into their user control?
Hey, I really do appreciate your help mate!However I have did another workaround, resetting the text style in override method OnFontChanged().Basically it just clear and re-write the text.Sounds not a good way, but it works well without performance issue.
Thanks for your help!
This might not be the necessary answer you're looking for, but I did have fun hacking away at the WinFormattedTextEditor. When you're in the design view they give you this really nice editor for the value of that text editor, so I thought it would be nice to use that on a form as well. Here's my insane results, with Office 2007 color scheming!
You can really put that editor into any container. In this example I used the form's fill panel since I made use of the WinFormManager, but you can shove it into any panel you want.
Office2007ColorTable.ColorScheme = Office2007ColorScheme.Black; Infragistics.Win.SupportDialogs.FormattedTextEditor.FormattedTextUIEditorForm editor_form = new Infragistics.Win.SupportDialogs.FormattedTextEditor.FormattedTextUIEditorForm(); editor_form = new Infragistics.Win.SupportDialogs.FormattedTextEditor.FormattedTextUIEditorForm(ultraFormattedTextEditor1); editor_form.TopLevel = false; editor_form.FormBorderStyle = FormBorderStyle.None; editor_form.Dock = DockStyle.Fill; editor_form.Visible = true; Infragistics.Win.UltraWinToolbars.UltraToolbarsManager top_toolmanager = Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.FromForm(editor_form); top_toolmanager.Style = Infragistics.Win.UltraWinToolbars.ToolbarStyle.Office2007; foreach (Control editor_control in editor_form.Controls) { switch (editor_control.Name) { case "pnlButtons": if (editor_control.Name == "pnlButtons") editor_control.Visible = false; break; case "ultraTabControl1": ((Infragistics.Win.UltraWinTabControl.UltraTabControl)editor_control).ViewStyle = Infragistics.Win.UltraWinTabControl.ViewStyle.Office2007; break; } } Form1_Fill_Panel.ClientArea.Controls.Add(editor_form);
This reply post was more of a for fun one, but if you have any questions about what I did above or how to change something, let me know.
I am looking around on UltraFormattedTextEditor finding the way to create multiple color in the text. Does it support multiple color in a textbox?On my previous sample project it just show a color, but on the actual I need it to support multiple color. That's the reason I use RichTextBox which support multiple text style in one place :)
Does anyone here have solution?I've found another person having the same problem last year and he doesn't get answered: http://community.infragistics.com/forums/p/47540/253744.aspx#253744Works around for multiple color in textbox is acceptable.Thanks.
