355
Overrule text of ComboEditor with check boxes.
I have an UltraComboEditor where I can select multiple values with check boxes. The text displayed is automatically generated (List of checked items separated with a comma).
I want to overrule this process with my own custom text.
How can I achieve this?
Thanks and kind regards,
Luc Verstreken
  • 69832
    I have a partial solution to this problem, using the IEditorDataFilter interface (see below). This does not, however, display the custom text when the control is in edit mode. You might be able to hack that out by getting a reference to the TextBox control embedded therein, and directly setting the Text property.
    public class MultiSelectDataFilter : IEditorDataFilter
        private UltraComboEditor comboEditor = null;
        private string displayText = null;
        public MultiSelectDataFilter( UltraComboEditor comboEditor, string displayText )
            this.comboEditor = comboEditor;
            this.displayText = displayText;
        #region IEditorDataFilter
        object IEditorDataFilter.Convert(EditorDataFilterConvertArgs conversionArgs)
            switch ( conversionArgs.Direction )
                case ConversionDirection.EditorToDisplay:
                case ConversionDirection.DisplayToEditor:
                    if ( this.comboEditor.CheckedItems.Count > 1 )
                        conversionArgs.Handled = true;
                        return this.displayText;
                    break;
            return conversionArgs.Value;
        #endregion IEditorDataFilter
