This is the WinForms tab control. I am not familiar with the web control so I cannot tell you if a similar property can be set on that one. You should post this question to the web tab forum: http://news.infragistics.com/forums/120.aspx
Mike,
Where do you do this? Can I do it through code? This is the web tab correct?
Thank in advance,
Thanks!
There is a built-in way to do this: Set the Style property to Wizard.
