Using NetAdvantage 9.2
I noticed the exception below when setting the Visible property on a specific node to True while the tree Visible value is still false. This node has several child nodes which I noticed had Visible True even when it's parent node Visible was False. Due to this observation I decided to add a loop to set the Visible property of all child nodes in addition to the parent node and so far this seems to be preventing the exception from being thrown under the same conditions. Is there any information regarding the cause of this exception?
exception text:
System.ArgumentException: Item has already been added. Key in dictionary: Value' Key being added: 'Value' at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add) at System.Collections.Hashtable.Add(Object key, Object value) at Infragistics.Win.UltraWinTree.NodeClientAreaUIElement.CacheNodeElements(Hashtable table, UIElementsCollection oldElements, Int32 startIndex) at Infragistics.Win.UltraWinTree.NodeClientAreaUIElement.PositionChildElements() at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements() at Infragistics.Win.UltraWinTree.UltraTreeUIElement.PositionChildElements() at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics) at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics) at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode) at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe) at Infragistics.Win.UltraWinTree.UltraTree.OnPaint(PaintEventArgs pe) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
The fix I came up outlined in the original post was sufficient for my organization so time was not taken to verify that the service release indeed fixes the issue.
Ok, I'll check that out. Thanks, Brian.
This sounds a lot like a bug that was fixed a while back. You should download the latest service release.
