410
how to change color of column in ultra grid while retriving data from database
hi
i want to change the color of column while loading windows form
example:-  i have a table like this:- table name status
columns are id, name status, description and values are ( 1, john, completed, work is done)
here status data is completed . now i want to show this completed in green in ultrgrid reaming columns are in normal colors
so any one having idea how to change the color of columns
By
N.Ravikumar
  • 69832
    Verified Answer
    UltraGridColumn exposes a Header property which in turn exposes an Appearance property. All Infragistics Appearance properties expose an object which has properties like ForeColor and BackColor. You can set these properties to change the colors; note that if the header is themed you will also have to set the ThemedElementAlpha property to Transparent.
    UltraGridColumn also exposes a CellAppearance property, which works exactly the same as the Header's Appearance, except that it applies to cells rather than the headers.
