920
WinChart Demarcation lines and scrolling
Hi
I've added two vertical demarcation lines to a line chart with the FillSceneGraph event.  I have two problems.
The first is using CInt(axisX.Map(target)).  The values on the xAxis are integers that represent dates and 15 minutes time periods i.e. 2010100400.  When I try to get a location on the x-axis to draw the line I get an arithmetic overflow error.  How do I correctly find the x-axis location ofr the line?
The second problem is that the lines do not scroll when the graph is scrolled.  As the chart scrolls, the lines are fixed in their x-axis position instead of scrolling to the correct x-axis location.  How do I get the lines to sync with the scroll window?
Any help greatly appreciated.
Regards
James O'Doherty
