I've recently encountered an error when I right click on one of my UltraCombo controls:
Could not load file or assembly 'Infragistics2.Win.UltraWinGrid.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.
I've encountered a similar error in the past. I tried numerous things to fix it and one apparantly worked by FLUKE chance. I do not quite understand what is going wrong and can't seem to fix it this time. Any help would be great!
Usually that is error caused by the highly annoying .licx file. You can delete its contents and that makes the problem go away without needing to upgrade.
hi cstodgell
i have face similar kind of error. the error is like this :
“Unable to resolve type 'Infragistics.Win.UltraWinTabControl.UltraTabControl, Infragistics2.Win.UltraWinTabControl.v6.2, Version=6.2.20062.34, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'
to resolve this i have done the following it may help u :-
Go to start--> Programs-->infragistics-->Netadvantage for. Net 2009.1-->Windowsforms-->Utility-->ProjectUpgradeUtility.
which means i think in u r project u r using infragistics 8.3 version but u installed older version of infragistics so u need to upgrade u r infragistics to 8.3 version to do that u have to do like this
