Hi All,
I have a Grid where I have attached a datatable which have some column to display.
It is my master ultra grid which is also used for saving and updating data.
I have two problem, If possible provide me a way to achieve...
After attaching datatable to grid, I added a unboud checkbox column to Grid (Code is below mentioned)
With grdDealFlow.DisplayLayout .Bands(0).Columns.Insert(.Bands(0).Columns.Count, "Saved") .Bands(0).Columns("Saved").DataType = GetType(Boolean) .Bands(0).Columns("Saved").Style = Infragistics.Win.UltraWinGrid.ColumnStyle.CheckBox .Bands(0).Columns("Saved").CellActivation = Activation.NoEdit .Bands(0).Columns("Saved").CellAppearance.FontData.Bold() = DefaultableBoolean.True .Bands(0).Columns("Saved").DefaultCellValue = False End With
Now I want to be check all row with value true. How can it possible.
I need my grid to be non-Insert able until he is not clicked on Add button.
After clicking on add button a new blank row will be added, So I can Input my detail inside that row
For Add New I will going use
Me.grdDealFlow.DisplayLayout.Bands(0).AddNew()
How can It possible that at initialize stage grid in not insert able but editable.
Thankx In Advance
Vijay
On which event I have to write that code for select all value in UnBound column when datasource is attached to grid
I'm afraid I didn't fully understand your question, but to set the value of a cell in an unbound column, you get a reference to the cell from the row's Cells collection, using the indexer that takes a reference to the unbound column or its key, and set it Value property. To make the value of that cell true for all rows, iterate the control's Rows collection, get a reference to the cell in the unbound column, and assign the value true to the cell's Value property.
