We are trying to display 4 charts in form using ultra tiles.We are facing one problem when we try to view all charts together.Scrren shot is attached.Is there any solution for this?
Jithesh
Hi Mike,
I was on vacation for some days.So I couldn't check the sample app you had sent earlier.I will check it and update you ASAP.
Apologies for the late reply.
Hi Jitesh,
Were you able to resolve this issue? Please let me know if you require further assistance.
Are you able to see the issue occuring in the attached sample? Please let me know if there are any differences between this sample and your project that you suspect of causing the issue.
Hello Mike,
This occurs when you try enalrge the chart and switching to normal mode many times.
In the beginning everything will be proper.If you continue to do the process,the size of some of the
charts reduce and the issue(which I had mentioned earlier) occurs.
Hello Jithesh,
I attempted to reproduce this issue, but was unsuccessful. Can you provide any more detail about the potential cause, or if possible, send us a reproduction sample?
