I use ultragridexcelexporter to excport to excel.
How to export in cardview?
I use version V8.1
sorry. yes I was looked wrong property.
Now it is ok.
Thank you Brother Mike.
Hi Felix,
I took a look at the this property and it's get/set in the version I have. So either you are looking at the wrong property, or else maybe you are using a very old version of the controls in which this property used to be get-only.
Hi
Thanks for your works on this (http://ko.infragistics.com/community/forums)website.
I also use ultragridexcelexporter to excport to excel.
Request Qn:) I want to change the e.CurrentRowIndex value in cell_exported event. But CurrentRowIndex property contains {get;} only. How can it possible?
Thank you.
CardView exporting is not supported. You should Submit a feature request to Infragistics
