765
convert values from source-unit to target-unit
I have several columns in the wingrid with numeric values.
In the column caption is the unit from the values.
For example:
 x[m]    y[mm]
2,145    0,649
0,245    7,442
Now I will convert the values from column y from the unit mm to cm (value / 10).
The new value with the unit cm should be in the same cell(0,649 > 0,0649).
How can I solve this problem?
Is there a solution with the wingrid (set the units (source-unit: mm, target-unit: cm) and call a command for this column)?
Alexander
  • 469350
    There are a couple of ways you can do this, but what approach you take will depend a lot on whether or not the cell is editable.
    Do you need the users to be able to edit this cell?
    If so, then I would create a UserControl and embed it in the grid cell using the UltraControlContainerEditor.
    If not, then it would be much easier to use either an unbound column or else use a CreationFilter to translate the real value into the text you want the user to see.
