hi
i have to show that the data on graphs format in grid for that i am using winchart . i am returning data through dataset (or i have to use datatable) . can i bind the data through dataset to winchart . if its possible how can i show in graphs
N.ravikumar
thanks a lot
Binding the chart to a data table or a dataset is fairly simple. chart.Data.DataSource = someDataTable;chart.Data.DataBind();or if you're using a dataset:chart.Data.DataSource = someDataSet;chart.Data.DataMember = "someMemberPath";chart.Data.DataBind();
I suggest downloading NetAdvantage samples, as there are many examples on how to use the chart.
