105
UltraWinToolbar Inheritance and events.
I am trying to create a custom control that inherits from the TextBoxTool. When I override the Method OnToolValueChanged to create some custom logic and add to the control it never fires. I can see that the control gets Instatiated with my inheriting class but when I put breakpoints in any of the overriden methods it never gets to them. Here is how I'm instantiating the class
public class ADACTextBoxTool : TextBoxTool
//public delegate void ProcessToolValueChanged(object sender, ToolEventArgs e);
public ADACTextBoxTool(string key): base(key)
and the overridden function that will not run.
protected override void OnToolValueChanged(ToolEventArgs e)
if (this.Text.Length >= 2 && _AutoCompleteSource == ShellAutoComplete.AutoCompleteFlags.ActiveDirectory)
_acListBox.Items.Clear();
_acListBox.Invalidate();
_acListBox.Items.AddRange(
ActiveDirectoryAutoComplete.GetAutoComplete(this.Text));_acListBox.Visible = true;
else
false;
base.OnToolValueChanged(e);
 My question is am I missing an interface that needs to be implimented or am I missing a setting in the control that needs to enable this? Any help is greatly appriciated.
Nic
  • 44743
    Verified Answer
    It sounds like your tool is being cloned internally, but the TextBoxTool's implementation of Clone is being used, so a new instance of TextBoxTool is being created. Overriding the Clone method should fix your issue. Try using the following code:
    protected override ToolBase Clone(bool cloneNewInstance)
     ADACTextBoxTool newTool = new ADACTextBoxTool( this.Key );
     newTool.InitializeFrom(this, cloneNewInstance);
     return newTool;
    Also, if you define any member variables in your derived tool and cloned tools should have those values copied over, you should also override InitializeFrom:
    protected override void InitializeFrom(ToolBase sourceTool, bool cloneNewInstance)
     base.InitializeFrom(sourceTool, cloneNewInstance);
     ADACTextBoxTool sourceTextBoxTool = sourceTool as ADACTextBoxTool;
     if ( sourceTextBoxTool == null )
      return;
     // Copy member variable values here
     this.member1 = sourceTextBoxTool.member1;
  • 69832
    This newsgroup is for the UltraNavigationBar control; you would be better off posting to the UltraWinToolbars newsgroup (http://news.infragistics.com/forums/102.aspx).
