585
Data displayed 'flat' in Gantt-Chart
I am using multiple UltraCharts in my project to display several Gantt-Charts. In an older Version the Gantt-Data was displayed ok as to be seen from screenshot Gantt_02.png.
Since the project has been upgraded from Infragistics version 7.3 to 9.2, the data in the Gantt-Chart is being displayed 'flat' as if all the rows would be displayed on top of each other with no height:
The actual code in my project has not changed, just the references to the newer Infragistics 9.2 assemblies.Also, the row descriptions have gone missing on the left side.
Have you seen anything like this before? I couldn't figure out what is causing this...
  • 585
    Verified Answer
    Got it, the effect was obviously caused by the usage of
    myUltraChart.Axis.Y.RangeMax = 1000d;
    myUltraChart.Axis.Y.RangeType = AxisRangeType.Custom;
    which seemed to work perfectly in earlier versions.
    However, I was able to get my Gantt chart back by setting the RangeType back to it's default value
    AxisRangeType.Automatic;
