Hei Guys,
I want to creat a composite chart with a ColumnLayer and a LineLayer.
The ColumnLayer has 2 Series.The result is:
how can i change the Appearance of the chart.
that the series ar combinde and the colors are red, green, red, green f.e.
Sry for my bad englisch :)
Regards
As long as the 2 column series are on the same column layer, you can use the following to make sure the data points alternate:myColumnLayer.SwapRowsAndColumns = true
