Hi!
I've encountered a weird problem : after adding a ultrawingrid on a form, the form's keyUp event does not trigger.
I got there like this : I've created a new windows forms application, put a message box on the KeyUp event and tested it - it worked - after that, i've added the grid, and the messagebox showed up no more!
Any ideea on this issue ? is this a know issue, or it appears only on my machine ?
O'm using NetAdvantage 2010.v3, win7, VS2010
Thanks!
Thanks Mike, you're right!
If you have no other controls on the form, then the KeyUp will be handled by the only control on that form - the grid. So the KeyUp event of the grid should fire, not the KeyUp event of the form.
I would think this would be true of any control that handles KeyUp for any reason.
If you follow the steps you listed here and use a TextBox instead of a grid, you get the same results.
If you want the form to get first crack at any keystrokes, then I think you can set the form's KeyPreview property to true.
anybody could reproduce this ?
