300
System.ArgumentException from System.Drawing if grouped view with image in the cell appearance
Hi there,
we use an Infragistics for WinForms 2010.1.
We have an UltraGrid derived Control with 4 grouped columns. The cells of one of this columns has set Appearance.Image property to a dynamically created Bitmap. This happens within an   InitializeRow handler of the grid.
The Bitmap are created like here:
private static Bitmap getAktionsArtImage(MasterData mdAktionsArt)
      if (mdAktionsArt != null && mdAktionsArt.Color is Color)
          var c = (Color)mdAktionsArt.Color;
          var img = new Bitmap(16, 16);
          using (Graphics g = Graphics.FromImage(img))
              g.FillRectangle(new SolidBrush(c), 0, 0, 15, 15);
          return img;
      return null;
By this constellation we change anything on the DataSource listand get an System.ArgumentException. What can be wrong here? Is this an Infragistics, my or .NET bug?
StackTrace:
bei System.Drawing.Image.get_Width()
bei System.Drawing.Image.get_Size()
bei Infragistics.Win.UltraWinGrid.GroupByRowDescriptionUIElement.PositionImageHelper(UltraGridGroupByRow row, Rectangle& workRect, GroupByRowDescriptionUIElement containerElem, UIElementsCollection oldElements)
bei Infragistics.Win.UltraWinGrid.GroupByRowDescriptionUIElement.PositionChildElements()
bei Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
bei Infragistics.Win.UltraWinGrid.RowColRegionIntersectionUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
bei Infragistics.Win.UltraWinGrid.DataAreaUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
bei Infragistics.Win.UltraWinGrid.UltraGridUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
bei Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive)
bei Infragistics.Win.ControlUIElementBase.VerifyIfElementsChanged(Boolean verify, Boolean syncMouseEntered)
bei Infragistics.Win.ControlUIElementBase.get_CurrentCursor()
bei Infragistics.Win.UltraControlBase.get_Cursor()
bei System.Windows.Forms.Control.WmSetCursor(Message& m)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
