I'm not sure how to put this but ...
I have a multi-row records with a couple of checkbox fields. If the record is only partially showing and the user selects one of the check boxes, the record is scrolled up but the checkbox is not checked. I'm not sure how to work this problem.
Any help would be appreciated.
Rose Anna
Thanks for the input. The problem discussed is my issue. The implementation solution -- not looking forward to. Are there plans to "fix" this problem in future versions? I am converting from UltraGrid 2.0 (Ultra Suite 3.02) and this was not an issue but a feature that my user expects.
Hi Rose Anna,
There's a similar question discussed here.
