On ultrawingrid 10.3.20103.2094, when i delete first row, all null values cells of the following row receive the cell value of the deleted row ???
I don't undersand ?
I can't do that easily... and i can't post my entire vsto project! I Think it's because i am manipulating datagrids thru lists and tabs....
Hello freuter,
Could you please try to recreate the mentioned behavior in a small sample which we will be glad to research further for you.
If you have any other questions please do not hesitate to ask.
There is no reason why deleting a row in the grid should affect any values in any other row. If that's happening, then something is clearly wrong.
Can you duplicate this behavior in a small sample project and post it here so was can check it out?
