I have create a hierachical grid with a dataset which makes the relationship between the two MSAccess tables so far so good.
How do I update and insert in the different tables from the grid. I have a wingridrowedittemplate for both bands in the grid. This works fine but how do I know update or insert the data back into the Msaccess tables?
Is there an easyway to identify the band of the grid the update or insert is done on?
I work in VB.Net
best Regards
Ronny Gilisen
The grid has no knowledge of, nor any interaction with, the back end (the database).
The grid only deals with it's local DataSource: in this case, the DataSet. The grid will update the tables in the DataSet and the DataSet will track those changes.
Typically, what you would do is use a DataAdapter to update the back end, just as you are probably using a DataAdapter to populate the DataSet in the first place.
