We are using cardview in one of our ultragrids.The cards are in compressed state.We need to select multiple cards (multiple rows) .We need this to happen when we drag the mouse.We are able to do this when we press Ctrl and select the required rows.
Is it possible to do the same without using the Ctrl button ?
If we try to select multiple rows using mouse,only first and last rows are getting selected(the row from where we start dragging the mouse and the row where we stop).
Jithesh
Hi Jithesh,
I already create a case for your request with reference number CAS-67763-PSTOOK. You could send updates to this case at any time. Please if you have any questions, do not hesitate to ask me
Regards
Hi Mike,
I also had tried that.But not working for cards.
I have submitted a feature request.
Jitheshk said: Is it possible to do the same without using the Ctrl button ?
I don't see any way to do this. Typically, you would just set the SelectTypeRow property to Extended (which is the default) and you could drag to select rows, but this doesn't seem to work for cards.
You should Submit a feature request to Infragistics
