350
How change the default count operation on GroupBy
When I apply a grouping operation by code like this:
Me.MainGrid.DisplayLayout.Bands (0). SortedColumns.Add ("ID", False, True)
The default operation for the group is a counter (COUNT).
In code, may be (VB or C #). NET
Question 1:
How do I change the type of operation for the group by a sum or average, for example?
Question 2:
Is it possible to change the default title when you group by a custom?
In advance thanks for your help ....
  • 469350
    xavendano2 said:
    Question 1:
    The count is automatic - it's not a summary or an "operation" really. Anyway, there are a couple of different ways to change the text of the GroupByRow. In this case, you will probably want to use the GroupByRowDescriptionMask property. This is basically a string with some replacement codes that allow you to determine what's displayed in each GroupByRow.
    The other way is to use the InitializeGroupByRow event on the grid and set e.Row.Description to whatever text you want.
    To add a Sum or Average or any other kind of summary to the grid, you can use the band.Summaries.Add method. Any summaries you add will, by default, show up in the GroupByRow as part of the description.
    xavendano2 said:
    Question 2:
    I'm not sure what you mean by "default title". But I guess you probably mean the text on the GroupByRow, in which case I have already answered that.
