I have a base grid class. I used that in different form, now when any form with the grid will be load I want to show no of records in a label, that I can do. My another requirement is when user will filter, that label will show filtered record number.
I want to do these in a event. So please help me regarding the same.
Thanks a lot.
Samaresh
i don't know if i understand right but i guess this is what you want:
private void ultraGrid1_AfterRowFilterChanged(object sender, AfterRowFilterChangedEventArgs e)
label1.Text = ultraGrid1.DisplayLayout.Rows.VisibleRowCount.ToString();
