215
XLS error when "Microsoft Office File Validation Add-In" update is applied
When the June 28th patch is applied to existing Office installations XLS files generated by the Infragistics.Excel object are flagged as having a bad format and a "Do you want to continue?" dialog appears, if you say yes the file is opened successfully.  XLSX files appear to be okay...
I'm currently using version 10.2.20102.2064, is there a later version that resolves this problem?
