65
Ribbon Tab Merging
In one of my projects, I am using an UltraWinToolbar set to display the Ribbon.  This sits on a MDIParent and each MDI Child has a Ribbon that merges into the parent Ribbon.  However, on the MDI children, I load controls that dynamically updates the Ribbon on the MDI Child that contains the control.  Of course, I call the RefreshMerge() method to resynch the child and parent Ribbons.  This works fine except that the Ribbon always jumps back to the zero index tab on the parent Ribbon.  I want to keep the same Ribbon tab active after the RefreshMerge call as was active before the method was called.
Additonally, I have a tab in the parent and in the child with the same name, but they will not merge their groups/tools together.  Instead, both tabs remain seperate.
 This is with the Infragistics NetAdvantage 2008 V1.
