Hi,I'm using a wincombo with some conditional format.The conditional format set the background to red if the value in the column exceeds a threshold. As long as no row is selected, it looks like this :
If you select a row with a red cell, it looks like this :
As you can see, on this immage it's impossible to see the selected row is covering the red background.Is it possible to change the active row background color to be somewhat transparent ?This would allow to see "through" the blue selected record and being aware it's covering a red cell.Regards,Ivan
No, it's not a free upgrade.
Can I perform this update (to 2009 version) for free?
Hi Yuri,
This feature was add in 2009. It does not exist in the 2007 version.
It's not impossible to achieve in that version. You could write code and use a DrawFilter to draw the highlight yourself. But it would be quite difficult and require a lot of code. I wouldn't recommend it. It would be a lot easier just to upgrade. :)
Hi! I have NetAdvantage for .NET 2007 Vol. 3 CLR 2.0 version. How can I get a semi transparent row highlight? Or it's not possible in this version?
Thanks!
I am updating this thread to let any interested parties know that this issue has been resolved in the currently available service release for NetAdvantage 11.1
The latest volume release is now available under your account at the Infragistics Website. To download the release, log in to ‘My IG’ and select ‘Keys & Downloads’. Select the appropriate tab for this product; then the license key. The volume release packages should now be listed on the page.
Sincerely,
Chris K
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
