150
UltraChart ignoring DateTime properties when using BindingList as data source
Slight issue/question with UltraWinChart displaying a LineChart.
I have a chart which used to use a BindingList as a data source. The BindingList was a collection of my proprietary objects, which have a number of public properties, for instance:
 public class ChartPoint {
    public DateTime Time { get { ... } }
    public int value1 { get { ... } }
    public double value2 { get { ... } }
However, no matter how much I experimented, I couldn't get the Chart to acknowledge that the first property was of type DateTime. The chart persistently showed "ROW1", "ROW2" etc as row labels. (My chart is a LineChart where I swap the axes, so each "row" is a point on my X-axis which is the time axis). And yes, I did set the TreatDateTimeAsString and RwoLabelsColumn and UseRowLabelsColumn properties.
After digging around these forums I saw another example where somebody had used a DataTable. I tried using one of those, explicitly creating a column of type DateTime, and then adding exactly the same values to the table as object[ arrays. This time around, the chart acknowledged the DateTime values and displayed them properly.
Is this a bug in the way the chart interacts with BindingLists?
 Many thanks.
