30
Tab event not being caught in UltraGrid
I'm having a very weird thing happen. It seems as if within the UltraGrid windows form tabbing through a row's cells is not working for some reason. I've confirmed this by making sure that tabstop was false on every control except for the grid and for the columns that I want to tab through are marked as tabstop = true. When I load up the form and click in one of the cells, the tab button does nothing. I even set up a key press event to try and advance to the next cell manually but the tab is not being caught in the event.
 Any ideas what might be causing this? I'm running out of ideas for a solution or workaround.
Joe Sullivan
Great Commission Ministries
