2715
Grid commit row
Hi!
I'm having an issue : i have a form with a grid on it. The grid can be edited, and the behaviour i need is the following : when editing a cell, if the Esc key is pressed i want the grid to commit the row and display a message.
At this moment the grid loses the newly entered data and return to the initial value when esc is pressed.
Here's how i've implemented (the isEditMode is a flag for when the grid is in edit mode, and HasModifiedValues is a flag that gets set to true on BeforeCellUpdate)
void ulgGrid_KeyUp(object sender, KeyEventArgs e) {
            if (e.KeyCode == Keys.Escape) {
                if (IsEditMode) {
                    ulgGrid.PerformAction(UltraGridAction.CommitRow);
                    if (HasModifiedValues) {
                        if (MessageBox.Show("You have some unsaved changes. Are you sure you want to roll them back?", "Warning!", MessageBoxButtons.YesNo) == System.Windows.Forms.DialogResult.Yes) {
                            CancelModifications();
                if (IsEditMode && !HasModifiedValues) {
Thank you!
