1339
WinGrid Throws Exception on BindingList update (w/ refreshsort)
I know the immediate response to this question is "sounds like a threading issue" and I don't disagree, but I don't see it being on our end.
The setup:
- Using the very latest service release of 10.3.
- I have a form with a typical grid bound to BindingSource.  The BindingSource in turn is bound to a BindingList.
- There are multiple instances of this form (grid/bindingsource), and each one is bound to the same, single instance of the BindingList.
- The BindlingList is updated every quarter second on a UI thread timer and ONLY on the UI thread (easily seen by looking at the code, and for sanity a logging method hooked to each bindingsource's ListChanged event shows it is only occuring on the UI thread). It's a very simple setup.
- After the update the grid is resorted (on the UI thread) via _grid.DisplayLayout.Bands[0].SortedColumns.RefreshSort(false);
The exception:
This is only seen every once in a while with no noticable pattern and isn't prompted by any user interaction.
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at Infragistics.Shared.SparseArray.ValidateIndex(Int32 index)
   at Infragistics.Shared.SparseArray.RemoveAt(Int32 index)
   at Infragistics.Win.UltraWinGrid.RowsCollection.OnListChangedHelper(ListChangedEventArgs e, Boolean calledFromBandListChanged)
   at Infragistics.Win.UltraWinGrid.RowsCollection.OnListChanged(Object sender, ListChangedEventArgs e)
   at System.ComponentModel.ListChangedEventHandler.Invoke(Object sender, ListChangedEventArgs e)
   at System.Windows.Forms.BindingSource.OnListChanged(ListChangedEventArgs e)
   at System.Windows.Forms.BindingSource.InnerList_ListChanged(Object sender, ListChangedEventArgs e)
   at System.ComponentModel.BindingList`1.OnListChanged(ListChangedEventArgs e)
   at System.ComponentModel.BindingList`1.FireListChanged(ListChangedType type, Int32 index)
   at System.ComponentModel.BindingList`1.RemoveItem(Int32 index)
   at System.Collections.ObjectModel.Collection`1.Remove(T item)
The question:
I know that a when you change the sort by clicking a column header, the sort will be done on a background thread by default (we are setting ProcessMode.Synchronous in the beforesortchange event handler to avoid issues there), but does RefreshSort do any manipulation on a different thread?
