195
Wintree not being recursed correctly
The below code used to work just fine as I recall. However, either I can't
get this to work correctly anymore due to a bug in my code or there's
something wrong with 11.1 UltraWinTree. Does this algorithm look right?
Thanks in advance, Don Bouchard
I'm calling this as follows:
utNodeFound = FindNode(utAccounts, nothing, "KEYDESIRED")
    Private Function FindNode(ByVal ut As UltraWinTree.UltraTreeByVal utNode As UltraWinTree.UltraTreeNodeByVal strKey As StringAs UltraTreeNode         Dim utNodes As TreeNodesCollection         ' If utNode is null, then assume we're starting at the top of the tree         ' otherwise, get this level's nodes and search them for a match         If utNode Is Nothing Then             utNodes = ut.Nodes         Else             utNodes = utNode.Nodes         End If         ' Now search in this level's nodes collection for a match         For Each utn As UltraTreeNode In utNodes             If String.Compare(utn.Key.Trim, strKey.Trim, True) = 0 Then                 Return utn             End If             If utn.HasNodes Then Return FindNode(ut, utn, strKey)         Next         Return Nothing     End Function
