1440
How to check if the column is in the view or not?
My grid has the first column group fixed, and our users has their customized views (setting columns to visible or not) saved in database.  The problem is that when user has lots of columns visible in the first column group, they can't horizontally scroll to the second column group because the view is all occupied by the first column group and it is a fixed group.
Is there a way I can determine if the last visible column in the group is not visible in the view?  In that case, I can manually remove the fixed property in InitializeLayout event.
Jason
