895
RenderingControl is not displayed after calling DisplayLayout.Load
The first time I show the form the  EditingControl / RenderingControl I setup on the grid column do show up as expected. Then when the form closes the DisplayLayout.Save(...) is called.
The second time I show the form the DisplayLayout.Load(...) is called and the EditingControl / RenderingControl I setup on the grid DO NOT show up as expected, they are empty cells.
I'm adding the UltraControlContainerEditor instance to a unbound column after the data binding.
Any ideas on how I can get the  EditingControl/RenderingControl to show up after the DisplayLayout.Load(...)?
Brian.
