I am very familiar with the ASP.NET grid, but am having a problem getting certain functionality working in the WinForm grid.
Basically, at the bottom of the Amount column (and only that column), I want to display a Sum of the Amount. I want the value to display at the bottom of the grid control, not at the end of all the rows. Currently, if I have 500 rows, it only shows after the 500th row. Also, I don't want the Sum icon in my column header - how can I get rid of that?
There must be some How-To's for this stuff that you can refer me to - I hope so!
Yes, that did it. Thank you very much. I would never have guessed the solution for removing the Sum icons. I thought it would be something named like ShowSumIcon.
Thanks again.
Walter
Add this in the InitializeLayout (or change it in the designer)
'Take out the sum icons
e.Layout.Override.AllowRowSummaries = UltraWinGrid.AllowRowSummaries.False
'Show summary fixed at the bottom
e.Layout.Override.SummaryDisplayArea = UltraWinGrid.SummaryDisplayAreas.BottomFixed
You change the format, etc in the SummarySettings object. You can access this at design time via DisplayLayout, bands(0), Summaries, or you can work with it in code.
Trausti
