685
vertical scrollbar affects column alignment
I have 4 grids on a form and need columns to align.
When (if) the vertical scrollbars on the right of any one of the grids appears then the columns do not align.
Is there some way of having the grid at a certain width but the last column is short enough to allow for a vertical scrollbar
should it appear?
  • 469350
     I'm not sure I understand your question. One thing you might consider is to set the ScrollBars property to Both so that the scrollbar shows up all the time. That way you don't have to worry about it.
